Connect directly to Wago buscoupler
Hi
Does anyone know if it is possible to connect Home Assistant directly to Wago’s fieldbus couplers? I guess it should be either the EtherCAT or the Modbus connectors that are the easiest to get to work. I want to be able to use their I/O modules, without having a PLC.
Modbus: https://www.wago.com/dk/io-systems/fieldbus-kobler-modbus-tcp/p/750-362
EtherCAT: https://www.wago.com/dk/io-systems/ethercat-fieldbus-kobler/p/750-354
How did you get it working?
I’m trying to get a Wago 750-362 modbus fieldcoupler working. It works directly with HASS, but it’s too slow. Because HASS can’t poll more often than 1x per second.
I’m curious if you had it working :slight_smile:
