Connect lights blueprint
I needed to enable a parallel-like connection between lights (which in how some ZigBee light switches show up to me), so I created a blueprint which will turn on/off lights when any of them is turned on/off.
This is the gist:
This is how it shows up, the only inputs are the lights you want to connect:
I’m not sure if there is already one that works similarly. This is my first blueprint, and I’m using it daily.
Cheers!
