Connect Schneider wireless without battery to HA
Hi :wave:
I recently purchased a schneider wireless switch without a battery. It is normally zigbee compatible but when I tried to connect it to the “Zigbee Home Automation” integration I never managed to display my module. I think this is because it doesn’t have a battery and it doesn’t output a continuous signal. Has anyone ever managed to integrate such a module?
The module:
Thanks you in advance :blush:
ZGP (Zigbee Green Power) devices are not yet supported in the ZHA integration, however, it now sounds like a developer might be working on code for zigpy, check out the related feature request discussion here → ZHA integration support for ZGP (Zigbee Green Power) devices via zigpy?
https://www.home-assistant.io/integrations/zha#limitations
ZHA does currently not support devices that can only use the ZGP (“Zigbee Green Power”) profile which is used in a few batteryless self-powered or energy harvesting devices, (such as for example; Philips Hue Click, Philips Hue Tap, and some “Friends of Hue” partnership switches).
This limitation of no ZGP support in the underlying software library that ZHA depends on is mentioned in the ZHA integration documentation but it is difficult to spot and understand what that means:
Ok thanks for the answer !!! So, i ll wait :blush:
Are you sure schneider wireless switch without a battery is using ZGP?
I understood it is using BLE.
