Hi have a Atom Lite module configured as BT proxy via ESPHome.
Setup via Ready-Made Projects — ESPHome
I bought several Shelly BLU Door/Window sensors that only communicate over bluetooth which I like to connect to via the Atom lite.
FYI: I do not own Shelly plus a device.
Is this possible and if so, how can I get these D/W sensor visble in home assistant?
Bieniu
(Maciek)
2
Yes, it is possible and you have to use BTHome integration.
Good day, did you manage to integrate the sensors in HA?
Can you share your experience?
Thank you
I only could manage to crreate the BT proxies, see screenshot.
I struggle how I can add the BLU sensor from here.
I tried to tripple click the BLU sensor but I don’t see it appear under new devices in HA.
Any tips?
Bieniu
(Maciek)
5
When the sensor is detected by BT Proxy, HA will prompt you to configure it with BTHome integration.
