Hi all!
Wondering if anyone can point me in the right direction in setting up a thread network with Home Assistant (with the goal of configuring some matter-over-thread devices).
Basically I’ve configured a Thread Border Router through my AP, which shows up as an “other network” in the Thread module in Home Assistant. However, I’m unable to get credentials when I try to configure using the Home Assistant iOS companion app. And when I try to add a device through Home Assistant via Matter (specifically an Eve Energy) I get the “Thread Border Router Required.”
A little stuck, not sure if the AP just isn’t compatible with Home Assistant or if I have to dig around for some code to pass the credentials over. Not sure if the problem is thread device to Border Router or Border router to Home assistant.
Devices/config:
- I have a Thread Border Router built into my AP (an AP5010).
-Trying to add an Eve Energy
-Running Home Assistant in a VM without Yellow or any built-in border router functionality since it’s on my AP
-Have the Matter (Beta) integration added
-Configuring the network, I’ve added a Network Key, PAN ID and a EXPAN ID (there’s also an option to configure a Thread Commissioner but not sure if that’s needed?)
Happy to share more info if helpful!
