Connect to 2 MQTT brokers
Hi all,
Is there an easy solution to connect to 2 MQTT brokers?
I have one running locally but als an broker thats running from a different IP in my network.
Can’t be done. You need to setup a mqtt bridge
Thanks! Where should i config this within Home assistant?
connection test-bridge
address 192.168.1.16
first :
Then modify mosquitto.conf
73326ad757ba1bd38a08d8fdee115c44ecfd412b_2_690x459
Getting some errors also can not find the folder share/mosquitto
