Hi there,
I have the following situation:
a device with its own MQTT Broker (IP: 192.168.1.1) - MQTT Integration is connected to this broker & working fine
a server with another MQTT Broker (IP: 192.168.1.2) → MQTT Integration can only be added once…
Do I need to Run a MQTT Broker as a bridge, which will collect the data from the different other brokers?
Or how could I connect HomeAssistant to both MQTT Brokers?
