I have a big problem and I just can’t get it fixed.
I have recently started running a Home Assistant installation on an Intel NUC and would like to connect it to my Homematic base which has been running for years on a Raspberry Pi with a HM-MOD-RPI-PCB radio module. I can’t get the config to work though.
I only use Homematic components and none from HomematicIP. Actually they are (except for an outdoor thermometer) only thermostats and window sensors.
Under Supervisor -> Homematic -> Config I have:
rf_enable: true
wired_enable: false
hmip_enable: false
rf:
- type: CCU2
device: /dev/ttyAMA0
wired:
- serial: xy
key: abc
ip: 192.168.0.0
hmip:
- type: HMIP_CCU2
device: /dev/ttyUSB0
regahss_reset: false
And in the configuration.yaml I have:
homematic:
interfaces:
rf:
host: 192.168.1.XX
port: 2001
ip:
host: 192.168.1.XX
port: 2010
hosts:
CCU2:
host: 192.168.1.XX
port: 2001
username: USER
password: PASSWORD
I always get this message in the LOG.
22:26:23] INFO: Setup BidCos-RF
/run.sh: line 52: /sys/class/gpio/export: No such file or directory
I have already tried various settings and just can’t get any further…
Can someone help me with that issue? Thank you.
