I’ve got HASS and MariaDB working correctly in Docker containers. I’m now looking at putting ZoneMinder on the same computer for my IP cameras. ZoneMinder needs access to MariaDB. I don’t want to install a copy of MariaDB outside of Docker, as it would be a waste of computer resources. Since I’m pretty new to Docker, I was wondering if anyone knew how to get an outside app to access a MariaDB container?
Thanks!
I’ve not used MariaDB, but it should be no different to just accessing it from another machine - you just need the IP address and port for the connection, and make the port accessible. Googling tells me the default port is 3306 - have you opened this up in your Docker config?
Yes, the port is already open in Docker. I’ve installed ZoneMinder and all of it’s dependencies. Now I will see if MariaDB can see the modules needed for ZoneMinder to work.
