Connect 'TP-Link Deco Service' in 'Home Assistant' to a 'TP-Link Deco Mesh Router' located remotely?
The above is the current setup.
How can the ‘TP-Link Deco Service’ in ‘Home Assistant’ connect to a ‘TP-Link Deco Mesh Router’ located remotely?
The available ‘VPN Server Options’ in the TP-Link Deco are the following.
  • OpenVPN
  • PPTP
  • L2TP/IPSec
Hello Kannan Balasubramanian,
Segmented networks are not officially supported within HA.
HA is designed and expects a flat subnet to work as intended.
This is because every segmented network is different for IP’s and number of segments and firewalls and sharing rules and about 650495849085 other things.
This does not mean you can’t use them or that they can’t be made to work, it means that to get them working you are the support structure on your own subnet(s). Consider it Advanced mode…
Thank you, you just confirmed my thoughts.
