Hi All,
My raspberry running dietpi (debian 11) with mosquitto broker and supervised homeassistant. In the homeassitant I added mqtt integration, and it connected to my local mqtt broker, no issue. But now I’m trying to install z2m, and it’s showing this
Zigbee2MQTT:info 2022-12-02 19:02:56: Connecting to MQTT server at mqtt://127.0.0.1
Zigbee2MQTT:error 2022-12-02 19:02:56: MQTT error: connect ECONNREFUSED 127.0.0.1:1883
Zigbee2MQTT:error 2022-12-02 19:02:56: MQTT failed to connect, exiting..
z2m config:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://127.0.0.1
serial:
port: /dev/ttyACM0
adapter: ezsp
Broker has no login/pass, it’s just my local machine.
Any suggestions appreciated! I’ve spend few hours trying to solve this with no result…
Thanks!
