New to Home Assistant
NUK with VM linux
I got this HUSBZB1 today… plugged it in thinking plug and play but nothing happened.
Any videos on how to install and configure?
https://www.amazon.com/dp/B01GJ826F8/ref=cm_sw_r_cp_apa_i_goU3EbZQS6YA3
NUK with VM linux
See https://www.home-assistant.io/docs/z-wave/. I have a HUSBZB1 and a NUC and use
zwave:
usb_path: /dev/ttyUSB0
But, I don’t use a VM. There are probably additional steps to make the stick visible in your VM.
how did you install HA?
You need do USB passthrough from the host to the VM you want to use that you want to use the stick in. How to do this depends on the hypervisor you used to setup the VM.
If you go to the “supervisor” page from left side menu, then to “system” tab, then “hardware” button, are there any devices listed there?
You should see something like this:
/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C0F007F9-if01-port0
/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C0F007F9-if00-port0
Hi @finity,
No, I don’t see that. Here is what I see
Hardware
- serial:
- /dev/ttyS0
- /dev/ttyS1
- /dev/ttyS3
- /dev/ttyS2
- input:
- Video Bus
- ImExPS/2 Generic Explorer Mouse
- VirtualBox USB Tablet
- AT Translated Set 2 keyboard
- Power Button
- Sleep Button
- disk:
- gpio:
- audio:
Also in Windows Device Manager “No Drivers Installed”
Ok… following the instructions HERE I was able to install the Windows Drivers.
But, I still don’t see the devices under hardware.
Do I need to share something in VirtualBox?
GOT IT!!!
I had to pull the stick and reinsert it… Now the devices appear in hardware
