So at 7am this morning, ALL 9 smoke detectors went off and thankfully there was no fire. But it looks like they are about 15 years old and it’s way past their useful life. I’m looking for suggestions on what to replace them with. So far, I think I am leaning towards Nest Protect but at 1100 bucks, I thought it was reasonable to solicit some more opinions to makE sure I was not missing something more obvious.
Here are the relevant stats:
9 detectors.
2 floors
all hardwired.
No alarm system but I am using all the alarm wires with an ESP to track status. (windows and doors). - Not sure If I can leverage any of that for the smoke detectors.
Are they interconnected to all go off at once? I would suspect so by what you described the error fault to be? If so you can use a minimote on the link wire between them to get Z-wave awareness of the status.
I did own Nest protects but would avoid them; lots of failures and eventually I switched away.
I know this post is kinda old but I just ordered these too and how do you know which smoke detector is which entity? I’ve added them but I’d like to give them a friendly name like “Smoke detector living room” but I have no idea how to identify them
I was thinking exactly these things! I’m going to remove them from the Xiaomi app, add them one by one and label them so I can’t mix’em up. Thanks tho!
I’ve bought a couple of these Xiaomi alarms hoping that its possible to have all alarms go off if smoke is detected, but I can’t find any info.
Maybe you guys could share some experience?
