Hi everyone.
I am planning on using the shelly dimmer 2 together with two momentary light switches. I plan to put the shelly in the socket above the lamp. The shelly dimmer 2 has two connection points called sw1 and sw2. Can I wire it with one input from each switch to the sw1 and sw2 and let the shelly control the switching from there or do i need to wire the two switches as I would for a normal two way switchable light and connect the output from that circuit to the sw1.
Thankful for your help
