Connecting an Enbrighten Dimming Light Switch to Dimmable LED through HA
I have been banging my head trying to figure this one out, and I think part of the issue is the “switch” that can be setup within HA. So, what I have so far. I have an Enbrighten Dimming Switch (https://www.amazon.com/gp/product/B08428YB81) and I want to have it control LED Light Panels using EuControls Zigbee Certified 20A Indoor Lighting Controller (https://www.amazon.com/gp/product/B084L3457C). I believe the way to control the on and off is with a script (unless there is a better way), but the biggest thing is controlling the dimming. Holding the switch up or down will cause the dimmer setting in HA for the switch to go up or down (in 3 or 4 jumps, so it isn’t like a sliding bar). I am trying to figure out the best way to control the dimming from the switch. I know I can do it in HA, but I would like the switch to control it as well.
I am very new to Home Assistant, and I haven’t explored Blueprints (which might be the way I need to go now that I think about it). Not sure if Blueprints will work with the switch though.
Anyone have any thoughts or can point me (or link me) in the right direction for setting dimming control up from the switch to control lights?
Thank you in advance for any help.
I guess are there any recommendations for using a Z-Wave/ZigBee Dimmer Switch to control Dimmable Lights? I can have the switch control the on and off (either physically or through HA), but I am not sure how to do the dimming. Any recommendations on setting up dimming within HA with the use of the physical switch (not just through the HA Dashboard)?
