So I have recently set up HA and connected several IP Cameras. In this building, there are a lot of old CCTV cameras that weren’t used for ~10 years, and I’d like to connect them to HA to still get some use from them since they are already there.
I found an old DVR from around 2004, I guess (The recommended OS is Windows XP/2000, and the CPU is a Pentium 4). Surprisingly it supports ethernet. I connected to it and got to where the camera feed would be, but instead, I saw:
“Please click here to download the installation program which does not support IE browser.
After finish downloading, disable the browser and implement the program by manual.”
When I loaded it in Edge in Internet Explorer compatibility mode and downloaded the program, I actually got a video feed! Of course, this wouldn’t work in HA, but this thing also supports RTSP!
When I tried it in Home Assistant, it gave me an error message “Timeout while loading URL”. I tried it in ContaCAM, and it seemed to connect, but this gave me the error “Error 5XX”. I really don’t know what is happening. Maybe HA doesn’t support some old RTSP protocol?
Yes, I do!
I am using the URL that the DVR specified:
rtsp://10.0.0.70/CH01
I put this same exact address in HA, and it did recognize something. However, it’s just a still image.
The weird thing is that I didn’t need any password or user name or need to specify the RTSP protocol. I also got the error “Error starting stream, see logs for details (0)”.
EDIT: I got it working with ContaCAM, but now I also noticed that the resolution is 176x144 when the camera supports 720x288.
Hi. Other than the resolution, everything is working fine!
I connected this weird camera through the motionEYE add-on and added the motionEYE integration, which allowed me to get a camera feed in Home Assistant!
If you know why please let me know what is wrong with the resolution
Try with rtsp adress ending in CH0 for the first stream. My NVR has ch nr 0 for stream 1, and 01 for substream 1 - with lower resolution. Maybe this is the case with your equipment.
And one more thing, try rtsp://10.0.0.70:554/CH01 - you never know
