Newbie here.
I’m connecting my wired zigbee gateway to a 4g modem. The modem has 2 output ethernet sockets. LAN and WAN.
Which one should i connect it too?
TIA
You mean 4G router/modem, correct? If so it should be connected to LAN. WAN would be a hardwired internet source.
LAN, the WAN port is in case you want to use it as a router only because you have an internet source.
Ahhh. Gotch. Many thanks
