in order to get the on/off-state of my lights I thought about switching to Zigbee-Wallswitches.
(Currently I’m using Broadlink RF-Switches in combination with a Braodlink RM)
I choosed the MOES Zigbee Wallswitch because I’m already using MOES valve radiators with Conbee II and thought that it can be integrated easily. Unfortunately I was wrong.
Has anyone of you already had experience with these light switches?
I can easily connect it with Smart Life and a Zigbee gateway. But not with Home Assistant and Conbee II.
I hope that someone has a solution for this - except using smart life integration.
It’s more than here. It will even not show up.
First I thought it’s damaged. But it works perfectly when I try it with Smart Life. But I don’t want to use it with Smart Life
Is this file the same as what should be configured for the Moes TS0011. Which is a single switch.
I am trying to set a few things on it without having to install the app as want to do it all in HA.
Like setting the light on the touch glass to be on all the time Moes ZTS-EU_1gang control via MQTT | Zigbee2MQTT
Hello everyone
please could you help me? I ask if the Moes wifi-RF 433 switches make 2 or 3 way multicontrol association with the Moes ZigBee switches
it is imprtant for me to be able to order
Hi John, unfortunately I was not able to connect it to Deconz.
I switched to Zigbee2MQTT with Conbee. This was a lot of boring work, reconnecting 74 devices
But everything works well und much smoother now. Also this MOES switch I got connected!
There is only one problem with this switch (I think maybe a hardware-problem of my model): Sometimes HA “thinks” that the light was successfully switched on after entering the room. But the room stays dark. The blue indicator-light of the wall-switch doesn’t change. I have to switch on the light manually. This happens ~once a month.
Hi guys not sure, if this thread is dead or not but i have these switch’s. Whilst i can pair them to zibee2mqtt, the dont work inside of home assistant and become unavailable. Im using a conbee 2 as well, did anyone have to do anything quirky to get them working?
Hi Andrew,
maybe a bit late … did you already got it working?
I had a similar isue with a new heater radiator last week.
For me it helped, switching to “Zigbee2MQTT Edge”. Now the radiator works well.
