Connecting NAS media to WDMyCloud / HACore/Rasp
it seems quite complicated to add a media path for mp3 music to the Home Assistant media.
It seems not to be just adding
homeassistant:
  media_dirs:
    media: \\192.168.1.57\Public\Shared Music
to the configuration.yaml.
When I approach
it seems, that in
I have to change settings, which show following info:
NOTE: You will not be able to edit anything in Configuration -> General in the UI if you are using YAML configuration for any of the following: name, latitude, longitude, elevation, unit_system, temperature_unit, time_zone, external_url, internal_url.
Can the media folder in WDMycloudNAS be added by keeping the edit via UI option?
Or do I misunderstood the warning?
What is your way on a Hass.io/HACore installation to add NAS media path?
Regards
Jörg
