Connecting Philips TV's running Titan OS
Has anyone had any succes in connecting a recent Philips television, running Titan OS to home assistant?
The ‘old’ Philips integration does not work afaik and connecting through matter has not been successful here.
There is an API for the OS but it seems to only focus on creating apps running on the devices itselves.
Would love to hear from someone who’s had better luck or someone with the skills to look into creating a new integration.
i tried the Philips TV integration and it works fine.
in the config you have to add:
HOST/IP:
and chose the API version 6
Start your TV before configure in Home Assistant
You will recieve an PINCODE on the Screen that you have to Enter in the Config-Prozess of the Integration.
I hope it will help you.
Thanks! I’ve managed to get it to work.
