Connecting Problems HA and InfluxDB
I’m currently getting used to the Home Assistant and am liking the system more and more.
I run HA in a VM as a supervisor with its own IP in the network. I also use an Influx DB in Docker on my Synology. The Influx DB can be reached via the shared port.
Unfortunately, I can’t get the Home Assistant to deliver the data to the Influx DB.
I’ve already looked at various instructions and still can’t find the error.
Bild Yaml
I also run Nodered as a VM with its own IP in the network and transferring data there with the Synology IP and the port for the InfluxDB works without any problems.
So unfortunately I have no idea what it could be.
Do you have an idea?
Matze
