flowersrj
(Rich F)
September 12, 2023, 4:50pm
1
I want to connect to my home generator web server at 192.168.0.90 by WIFI for use in HA. However, my HA ethernet network is 192.168.1.x determined by a FIOS router.
Purchased an external USB antenna to attempt a connection. I am using the Raspian image install of HA.
I am stuck at this point. Is this the way to go? Has anyone done this before?
Thanks,
Rich
koying
(Chris B)
September 12, 2023, 6:10pm
2
I assume your “Wifi” router is connecterd to your “FIOS” router?
Do you explicitly want 2 networks? If not, you can try to put your Wifi router in “Access point” mode or equivalent, so, that your main router provides the IP adresses.
flowersrj
(Rich F)
September 12, 2023, 9:09pm
3
Chris B,
My FIOS router is a gateway router with fixed IP addressing of 192.168.1.x. My home generator also has fixed IP addressing of 192.168.0.90.
Rich
francisp
(Francis)
September 13, 2023, 4:05am
4
flowersrj:
Is it recognised by the OS ?
Raspian image install of HA ? Is that HA OS or a venv install on Raspbian ?
flowersrj
(Rich F)
September 13, 2023, 12:49pm
5
I am using the Raspian image of HA. Don’t know how to tell if antenna is recognized.
francisp
(Francis)
September 13, 2023, 12:52pm
6
Raspian image of HA is nowhere to be found in the official installation guides.
What does settings->system->repairs-> 3dots in the upper right corner->system information say ?
francisp
(Francis)
September 13, 2023, 2:07pm
8
So you are using HA OS.
Under settings → system → network, do you have a wlan tab ?
flowersrj
(Rich F)
September 13, 2023, 2:41pm
9
Yes I do.
So I just now selected WIFI under it and see the generator, so I added the password. It now says connected.
Then I added this binary sensor but it says “off” under STATES in Developer Tools. However, I can access it on my phone by going to 192.168.0.90.
francisp
(Francis)
September 13, 2023, 3:04pm
10
Can you ping from one of the SSH add-ons ?
flowersrj
(Rich F)
September 13, 2023, 3:19pm
11
Yes, tried from the Terminal Add-on, no response was returned. I was able to ping 8.8.8.8 plus my FIOS router successfully.
francisp
(Francis)
September 13, 2023, 3:31pm
12
Could be, on the same page, that you have to change this too:
(The extra choices only show , when auto configure is not selected)
flowersrj
(Rich F)
September 13, 2023, 3:40pm
13
I don’t see that page. I am using Ethernet to connect to network.
I had previously disabled WIFI chip on board some time ago but don’t remember how. I believe it was at boot time don’t know how to to those options.
francisp
(Francis)
September 13, 2023, 3:42pm
14
it is on the bottom of that page.
francisp
(Francis)
September 13, 2023, 3:56pm
16
Ok, scan for Wifi, password, but IPv4 has to be automatic
flowersrj
(Rich F)
September 13, 2023, 4:26pm
17
Same result with 'Automatic" selected.
So I removed external antenna temporarily, rebooted HA and only the SSID ‘NotAvailable’ shows up which is my FIOS router’s WIFI SSID.
I was told Rapsberry PI WIFI chip needed to be disabled which I figure means 'NotAvailable SSID should not show up HA.
SSID ‘Champion-2799’ is for the generator which I am trying to use external antenna for.
Pinging to it still fails but still able to ping 8.8.8.8
flowersrj
(Rich F)
September 13, 2023, 4:38pm
18
How would one disable the WIFI chip on Raspberry PI 4 but not the WIFI software so that external antenna could use it? How can I see the BOOT options?
francisp
(Francis)
September 13, 2023, 5:01pm
19
You still see the Wlan tab with the USB adapter unplugged ?
flowersrj
(Rich F)
September 13, 2023, 10:17pm
20
Yes. It just lists the SSID for the FIOS router.
