Hi
I recently acquired an environexus automation system by Nero.
https://environexus.com/ which use similar hardware as Vera automation.
Is there is a way to me to connect to Nero interface?
Dilan
Hi
Dilan
Hi Dilan,
Did you find a way to connect to Nero interface? I’ll be attempting to do the same and it would be great if you had any tips or instructions to share.
Paul
HI Dilan and Paul.
Have either of you had any luck with Nero and home assistant integration? I’m hoping to do the same…
This worked, seems to be the same product as nero
