Hi. I’m running hassio on a Rasberry pi 4.
I’d like to use the Heatmiser integration to control my 12v wired Heatmiser thermostats.
The docs say
“The module itself is currently setup to work over a RS232 -> RS485 converter, therefore it connects over IP.”
I have this usb to RS485 cable that shows up in Hardware as
/dev/serial/by-id/usb-FTDI_USB-RS485_Cable_FT3MBZES-if00-port0
Can this be used? If so what should I put in the config for ip and port?
Thanks.
