I have just discovered that if I have set the hidden: true parameter for the network, ESPHome will not connect if it isn’t hidden (I was replacing the AP and changing the network configuration).
Is this by design to meet a specification somewhere or is it a bug?
Once the AP was set to hidden, the devices connected even without the fast_connect parameter being set
You know how to go to the esphome.io website and use a search box right? You could type “fast connect” in rhe search box and that will take you to where it explains it and how to set it.
