Hi there, I believe you are using mosquito mqtt in HA. In that case you can inter-connect with Hisence mqtt broker with the process known as bridging. Please see the below for details.
You will have to change the configuration in addon and also create a file with the relevant bridge setting. Please see the below guide.
