Connecting two platforms to EVL4 envisalink board
anyone using DscServer.Jar with Envisalink or envisalink_new Home Assistant integration? Or anyone with suggestions on a method to allow multiple platforms (in my case hoobs and HA) to connect to the EVL4 board?
since the evl4 boards only allow one simultaneous connection (like from HA) I use the DscServer.Jar as a proxy to allow multiple platforms (in my case hoobs and HA) to connect to the DSC EVL4 alarm systems. My problem is from HA a zone opening is not persistent (a door will show closed after 30 seconds in HA when the door is not really closed). It works fine when I don’t use the ‘DscServer.jar’ proxy. Curious if anyone else has a solution?
