Here are all the logs:
2018-12-03 16:09:48 DEBUG (MainThread) [pydeconz.utils] Sending {} to http://127.0.0.1:8080/api/0353B643B9
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz.utils] HTTP request response: {‘config’: {‘UTC’: ‘2018-12-03T16:09:49’, ‘apiversion’: ‘1.16.0’, ‘backup’: {‘errorcode’: 0, ‘status’: ‘idle’}, ‘bridgeid’: ‘00212EFFFF024835’, ‘datastoreversion’: ‘60’, ‘devicename’: ‘RaspBee’, ‘dhcp’: True, ‘factorynew’: False, ‘fwversion’: ‘0x26050500’, ‘gateway’: ‘192.168.1.1’, ‘internetservices’: {‘remoteaccess’: ‘disconnected’}, ‘ipaddress’: ‘192.168.1.8’, ‘linkbutton’: False, ‘localtime’: ‘2018-12-03T16:09:49’, ‘mac’: ‘b8:27:eb:f7:44:13’, ‘modelid’: ‘deCONZ’, ‘name’: ‘Phoscon-GW’, ‘netmask’: ‘255.255.255.0’, ‘networkopenduration’: 60, ‘panid’: 10621, ‘portalconnection’: ‘disconnected’, ‘portalservices’: False, ‘portalstate’: {‘communication’: ‘disconnected’, ‘incoming’: False, ‘outgoing’: False, ‘signedon’: False}, ‘proxyaddress’: ‘none’, ‘proxyport’: 0, ‘replacesbridgeid’: None, ‘rfconnected’: True, ‘starterkitid’: ‘’, ‘swupdate’: {‘checkforupdate’: False, ‘devicetypes’: {‘bridge’: False, ‘lights’: [], ‘sensors’: []}, ‘notify’: False, ‘text’: ‘’, ‘updatestate’: 0, ‘url’: ‘’}, ‘swupdate2’: {‘autoinstall’: {‘on’: False, ‘updatetime’: ‘’}, ‘bridge’: {‘lastinstall’: ‘’, ‘state’: ‘allreadytoinstall’}, ‘checkforupdate’: False, ‘install’: False, ‘lastchange’: ‘’, ‘lastinstall’: ‘’, ‘state’: ‘allreadytoinstall’}, ‘swversion’: ‘2.5.47’, ‘timeformat’: ‘12h’, ‘timezone’: ‘Etc/GMT’, ‘uuid’: ‘39fd436f-5b0a-4b79-b0ad-8d80630dc630’, ‘websocketnotifyall’: True, ‘websocketport’: 8443, ‘whitelist’: {‘0353B643B9’: {‘create date’: ‘2018-12-02T11:23:03’, ‘last use date’: ‘2018-12-03T16:09:49’, ‘name’: ‘pydeconz’}, ‘0D335EE6A6’: {‘create date’: ‘2018-12-02T11:17:07’, ‘last use date’: ‘2018-12-03T16:09:46’, ‘name’: ‘Phoscon#B1920x938’}, ‘22C65D763D’: {‘create date’: ‘2018-12-03T10:08:28’, ‘last use date’: ‘2018-12-03T16:08:23’, ‘name’: ‘my application’}}, ‘zigbeechannel’: 15}, ‘groups’: {‘1’: {‘action’: {‘bri’: 127, ‘colormode’: ‘hs’, ‘ct’: 0, ‘effect’: ‘none’, ‘hue’: 0, ‘on’: False, ‘sat’: 127, ‘scene’: None, ‘xy’: [0, 0]}, ‘class’: ‘Other’, ‘devicemembership’: [], ‘etag’: ‘3b8dee02c07678a03443a5fedede11d2’, ‘id’: ‘1’, ‘lights’: [], ‘name’: ‘hall’, ‘scenes’: [], ‘state’: {‘all_on’: False, ‘any_on’: False}, ‘type’: ‘LightGroup’}}, ‘lights’: {}, ‘resourcelinks’: {}, ‘rules’: {‘3’: {‘actions’: [{‘address’: ‘/lights/1/state’, ‘body’: {‘on’: True}, ‘method’: ‘BIND’}], ‘conditions’: [{‘address’: ‘/sensors/2/state/buttonevent’, ‘operator’: ‘eq’, ‘value’: ‘4’}], ‘created’: ‘2018-12-03T13:51:59’, ‘etag’: ‘b38cab97476de0413c7495f50aca74e2’, ‘lasttriggered’: ‘none’, ‘name’: ‘Switch hall upper lights On/Off’, ‘owner’: ‘22C65D763D’, ‘periodic’: 0, ‘status’: ‘enabled’, ‘timestriggered’: 0}}, ‘schedules’: {}, ‘sensors’: {}}
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz] {‘config’: {‘UTC’: ‘2018-12-03T16:09:49’,
‘dhcp’: True,
‘panid’: 10621,
‘incoming’: False,
‘outgoing’: False,
‘signedon’: False},
‘proxyport’: 0,
‘starterkitid’: ‘’,
‘lights’: [],
‘sensors’: []},
‘notify’: False,
‘text’: ‘’,
‘updatestate’: 0,
‘url’: ‘’},
‘install’: False,
‘lastchange’: ‘’,
‘lastinstall’: ‘’,
‘colormode’: ‘hs’,
‘ct’: 0,
‘effect’: ‘none’,
‘hue’: 0,
‘on’: False,
‘sat’: 127,
‘scene’: None,
‘xy’: [0, 0]},
‘class’: ‘Other’,
‘id’: ‘1’,
‘lights’: [],
‘name’: ‘hall’,
‘scenes’: [],
‘lights’: {},
‘method’: ‘BIND’}],
‘operator’: ‘eq’,
‘value’: ‘4’}],
‘periodic’: 0,
‘schedules’: {},
‘sensors’: {}}
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz.config] Deconz config loaded {’_apiversion’: ‘1.16.0’, ‘_bridgeid’: ‘00212EFFFF024835’, ‘_linkbutton’: False, ‘_mac’: ‘b8:27:eb:f7:44:13’, ‘_modelid’: ‘deCONZ’, ‘_name’: ‘Phoscon-GW’, ‘_networkopenduration’: 60, ‘_panid’: 10621, ‘_swversion’: ‘2.5.47’, ‘_uuid’: ‘39fd436f-5b0a-4b79-b0ad-8d80630dc630’, ‘_websocketport’: 8443, ‘_zigbeechannel’: 15}
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz.deconzdevice] hall created as
{’_all_on’: False,
‘_any_on’: False,
‘_async_callbacks’: [],
‘_async_set_state_callback’: <bound method DeconzSession.async_put_state of <pydeconz.DeconzSession object at 0x732801f0>>,
‘_bri’: 127,
‘_class’: ‘Other’,
‘_colormode’: ‘hs’,
‘_ct’: 0,
‘_deconz_id’: ‘/groups/1’,
‘_devicemembership’: [],
‘_effect’: ‘none’,
‘_etag’: ‘3b8dee02c07678a03443a5fedede11d2’,
‘_hidden’: None,
‘_hue’: 0,
‘_id’: ‘1’,
‘_lights’: [],
‘_lightsequence’: None,
‘_manufacturername’: None,
‘_modelid’: None,
‘_multideviceids’: None,
‘_name’: ‘hall’,
‘_on’: False,
‘_reachable’: True,
‘_sat’: 127,
‘_scenes’: {},
‘_swversion’: None,
‘_type’: ‘LightGroup’,
‘_uniqueid’: None,
‘_x’: 0,
‘_y’: 0}
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz.websocket] Websocket starting
2018-12-03 16:09:49 DEBUG (MainThread) [pydeconz.websocket] Websocket running
2018-12-03 16:14:51 DEBUG (MainThread) [pydeconz] Unsupported event {‘config’: {‘on’: True, ‘reachable’: True, ‘temperature’: 2300}, ‘e’: ‘changed’, ‘id’: ‘4’, ‘r’: ‘sensors’, ‘t’: ‘event’, ‘uniqueid’: ‘00:15:8d:00:02:9b:1a:4c-04-0006’}
2018-12-03 16:14:51 DEBUG (MainThread) [pydeconz.websocket] Websocket data: {“config”:{“on”:true,“reachable”:true,“temperature”:2300},“e”:“changed”,“id”:“4”,“r”:“sensors”,“t”:“event”,“uniqueid”:“00:15:8d:00:02:9b:1a:4c-04-0006”}
2018-12-03 16:17:45 DEBUG (MainThread) [pydeconz.websocket] Websocket starting
2018-12-03 16:17:45 DEBUG (MainThread) [pydeconz.websocket] Reconnecting to deCONZ in 15.
2018-12-03 16:18:00 DEBUG (MainThread) [pydeconz.websocket] Websocket starting
2018-12-03 16:18:00 DEBUG (MainThread) [pydeconz.websocket] Websocket running
