Hi there ! I’m having some issues with both my esp (d1 and d1_mini_pro) : Even if my router show them as connected, i can’t connect to them and the graphics on home assistants are showing there is some problems : as you can see there is a lot of little dots
INFO Trying to reconnect to espgaz.local in the background
INFO Successfully connected to espgaz.local
[19:11:16][D][api:098]: Accepted 192.168.50.84
[19:11:16][D][api.connection:736]: Home Assistant 2021.12.0 (192.168.50.84): Connected successfully
INFO espgaz.local: Ping timed out!
ERROR Exception in callback _ProactorBasePipeTransport._call_connection_lost(None)
handle: <Handle _ProactorBasePipeTransport._call_connection_lost(None)>
File "c:\users\valen\appdata\local\programs\python\python39\lib\asyncio\events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "c:\users\valen\appdata\local\programs\python\python39\lib\asyncio\proactor_events.py", line 162, in _call_connection_lost
self._sock.shutdown(socket.SHUT_RDWR)
OSError: [WinError 10038] Une opération a été tentée sur autre chose qu’un socket
INFO Disconnected from ESPHome API for espgaz.local
WARNING Disconnected from API
WARNING Can't connect to ESPHome API for espgaz.local: Error connecting to ('192.168.50.146', 6053): [WinError 121] Le délai de temporisation de sémaphore a expiré
