Hi there, i have HA OS instance running in my LAN network and i can access it perfectly via internal IP in LAN. I have also set nginx reverse proxy on my router (gateway) that handles requests from “outside” to services in my LAN (HA, Nextcloud, …) based on requested subdomain. Nginx have a valid SSL cert and the encrypted connection ends here (at nginx proxy) and further is forwarded in LAN as an unencrypted.
And here is the problem:
When i access HA from outside via http: the page (frontend) loads perfectly.
But when i go via https: the frontend (even login page) is broken. Sometimes the frontend dont load at all, sometimes there are missing pieces of page. The zigbee2mqtt panel never loads!
Others services like nextcloud, portainer works perfectly.
So nginx is working perfectly when handling connection without SSL, but with SSL im observing some connections losses (not all JS requests can be loaded).
Im not expert in nginx conf but i follow many guides (also here) but no one works.
Im attaching part of my configuration.yaml and my nginx configuration…
server {
listen 80;
listen 443 ssl;
server_name hass.xxx.xxx.net;
ssl_certificate /root/.acme.sh/xxx.xxx.net/xxx.xxx.net.cer;
ssl_certificate_key /root/.acme.sh/xxx.xxx.net/xxx.xxx.key;
proxy_buffering off;
location / {
proxy_pass http://192.168.1.233:8123/;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
#proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
Note: i had commented X-Forwarder-For because then it throwing error 400 Bad request
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
homeassistant:
external_url: https://hass.xxx.xxx.net
internal_url: http://192.168.1.233:8123
python_script:
#NGINX proxy setting
http:
use_x_forwarded_for: true
cors_allowed_origins: https://hass.xxx.xxx.net
trusted_proxies:
- 191.168.1.1
server_port: 8123
script: !include scripts.yaml
scene: !include scenes.yaml
Any suggestions are welcome.
Thanks. Andrej.
