Connection of external Livolo zigbee gateway possible
I am new to Home assistant and working my way through it.
As I just received a new Livolo zigbee and a white label zigbee gateway, I was wondering I these could work with homeassistant somehow. There is a standard wifi connection with the router so I hope that can be used to connect to the HA server.
Brand Name: choifoo
Origin: CN(Origin)
Model Number: Zigbee+Wifi+Sig-Mesh Hub
State of Assembly: Ready-to-Go
Product name: WIFI+Zigbee smart gateway
Communication method: Zigbee, Sig-Mesh
Working parameters: DC5V/2A
Working temperature: 0℃—55℃
Product size: 707015mm
Search for devices and automatically join them to the network, no need to consider network parameter configuration, the module automatically selects and sets optimized parameters
  1. Built-in 256Mb flash memory and 1Gb RAM
  2. Support secondary development and provide perfect interface protocol
  3. Customer configuration is simple and convenient, easy to expand, products are interoperable, and communication is stable and reliable
  4. The high-performance version of the WIFI module and the TI solution enhanced version of Zigbee, 433 modules form a stable, reliable, and intelligent gateway for data transmission and reception
  5. The certified equipment using this module is compatible with other ZHA standard equipment
Hi mate, have you have any luck with this? I have just started building my home assistant network and I have a G2 gateway to control my roller blinds, but have had no luck trying to integrate them…
