Login not possible. Please check your setting and/or your credentials
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 165, in connection_is_valid
server = self.connect()
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 158, in connect
mail.login(self.username, self.password)
File "/usr/local/lib/python3.12/smtplib.py", line 750, in login
raise last_exception
File "/usr/local/lib/python3.12/smtplib.py", line 739, in login
(code, resp) = self.auth(
File "/usr/local/lib/python3.12/smtplib.py", line 662, in auth
raise SMTPAuthenticationError(code, resp)
smtplib.SMTPAuthenticationError: (535, b'Incorrect authentication data')
The username and password are correct, as they also work with Node-Red.
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 108, in async_setup_platform
notify_service = await hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 103, in get_service
if mail_service.connection_is_valid():
File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 144, in connect
mail = smtplib.SMTP_SSL(
File "/usr/local/lib/python3.12/smtplib.py", line 1022, in __init__
SMTP.__init__(self, host, port, local_hostname, timeout,
File "/usr/local/lib/python3.12/smtplib.py", line 255, in __init__
(code, msg) = self.connect(host, port)
File "/usr/local/lib/python3.12/smtplib.py", line 341, in connect
self.sock = self._get_socket(host, port, self.timeout)
File "/usr/local/lib/python3.12/smtplib.py", line 1029, in _get_socket
new_socket = self.context.wrap_socket(new_socket,
File "/usr/local/lib/python3.12/ssl.py", line 455, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.12/ssl.py", line 1042, in _create
self.do_handshake()
File "/usr/local/lib/python3.12/ssl.py", line 1320, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1000)
