i keep getting this error . but the google maps sensor seams to work
has any one any idea why or how to fix it ?
2017-09-22 12:22:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.to_workcar fails
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py”, line 83, in create_connection
raise err
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py”, line 73, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network unreachableDuring handling of the above exception, another exception occurred:
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 345, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 844, in _validate_conn
conn.connect()
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 284, in connect
conn = self._new_conn()
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 150, in _new_conn
self, “Failed to establish a new connection: %s” % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7f041dd02f98>: Failed to establish a new connection: [Errno 101] Network unreachableDuring handling of the above exception, another exception occurred:
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 438, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/retry.py”, line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘maps.googleapis.com’, port=443): Max retries exceeded with url: /maps/api/distancematrix/json?departure_time=now&destinations=DESTINATION&mode=driving&origins=STARTPOINT&units=metric&key=APIKEY (Caused by NewConnectionError(‘<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7f041dd02f98>: Failed to establish a new connection: [Errno 101] Network unreachable’,))During handling of the above exception, another exception occurred:
File “/usr/lib/python3.6/site-packages/googlemaps/client.py”, line 229, in _request
**final_requests_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 531, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 518, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 639, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 502, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘maps.googleapis.com’, port=443): Max retries exceeded with url: /maps/api/distancematrix/json?departure_time=now&destinations=DESTINATION&mode=driving&origins=STARTPOINT&units=metric&key=APIKEY (Caused by NewConnectionError(‘<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7f041dd02f98>: Failed to establish a new connection: [Errno 101] Network unreachable’,))DESTINATION
