'Connection to MYDOMAIN.COM timed out. (connect timeout=10)'))
Hi All,
Can someone tell me what to do?
Always worked and since 0.107.4 I get those errors:
2020-03-21 20:39:56 ERROR (SyncWorker_7) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xac5af130>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:40:34 ERROR (SyncWorker_18) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae24f850>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:40:58 ERROR (SyncWorker_14) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xad350850>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:41:30 ERROR (SyncWorker_14) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae0be4d0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:41:44 ERROR (SyncWorker_11) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xad611670>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:44:42 ERROR (SyncWorker_2) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection
2020-03-21 20:49:16 ERROR (SyncWorker_10) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae099f50>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:49:52 ERROR (SyncWorker_10) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xaf8a9730>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:54:29 ERROR (SyncWorker_11) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae116b30>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:57:30 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae1d24b0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:00 ERROR (SyncWorker_1) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae6475b0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:10 ERROR (SyncWorker_19) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xac7f67f0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:20 ERROR (SyncWorker_1) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xafd79030>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:30 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xad358f50>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:40 ERROR (SyncWorker_10) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae248370>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:58:50 ERROR (SyncWorker_3) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae4a8810>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:59:00 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xaf8e0730>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:59:10 ERROR (SyncWorker_5) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection
2020-03-21 20:59:20 ERROR (SyncWorker_4) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection
2020-03-21 20:59:30 ERROR (SyncWorker_14) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xac69c290>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 20:59:40 ERROR (SyncWorker_17) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xac5afed0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:03:18 ERROR (SyncWorker_1) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xafd8de70>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:07:56 ERROR (SyncWorker_11) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae2d4c90>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:12:32 ERROR (SyncWorker_5) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/ssh.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /ssh.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xaec15d70>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:12:42 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae2ea3b0>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:15:02 ERROR (SyncWorker_15) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/www.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /www.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0xae1a3f70>, 'Connection to DOMAINNAME.COM timed out. (connect timeout=10)'))
2020-03-21 21:16:38 ERROR (SyncWorker_1) [homeassistant.components.rest.sensor] Error fetching data: http://DOMAINNAME.COM/vmail.json failed with HTTPConnectionPool(host='DOMAINNAME.COM', port=80): Max retries exceeded with url: /vmail.json (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection
domainname.com would appear to be down.
I hidden my real domain name… this is only a replacement
my domain is working, when I do a wget with same link on RPi4 where Hassio is running I get the Json file without problems.
# SENSOR REST
# https://www.home-assistant.io/integrations/rest/
platform: rest
resource: !secret mvpsjsonssh
method: GET
name: "MVPS SSH Login User"
value_template: "{{ value_json['ssh']['user'] }}"
I can ping the domain inside the homeassistant docker
I can do wget inside the homeassistant docker
So basically the link is working.
this problem is not every minute but keeps coming in the log file.
I cant solve this tried many things…
