Hi all,
it is not possible for me to establish a connection between my Home Assistant(Docker) and my Raspberrymatic.
The error in the log:
2019-10-04 19:15:53 WARNING (SyncWorker_13) [pyhomematic._hm] Failed connecting to proxy at http://192.168.1.27:2001
2019-10-04 19:15:53 CRITICAL (SyncWorker_13) [pyhomematic.connection] Failed to create server
2019-10-04 19:15:53 CRITICAL (SyncWorker_13) [pyhomematic.connection] Failed to start server
2019-10-04 19:15:53 ERROR (MainThread) [homeassistant.setup] Error during setup of component homematic
File "/usr/local/lib/python3.7/site-packages/pyhomematic/connection.py", line 73, in start
self._server.start()
AttributeError: 'HMConnection' object has no attribute '_server'
File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/usr/src/homeassistant/homeassistant/components/homematic/__init__.py", line 410, in setup
homematic.start()
File "/usr/local/lib/python3.7/site-packages/pyhomematic/connection.py", line 79, in start
self._server.stop()
I opened a bash on the running docker container and was able to ping my raspberrymatic. Portscan successfully showed that the port 2000,2001 and 2010 are open.
Raspberrymatic IP: 192.168.1.27
Home Assistant: 192.168.1.220
Home Assistant config:
GNU nano 3.2 configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
homematic:
local_ip: 192.168.1.220
interfaces:
rf:
host: 192.168.1.27
resolvenames: json
username: Admin
password: <>
wired:
host: 192.168.1.27
port: 2000
resolvenames: json
username: Admin
password: <>
ip:
host: 192.168.1.27
port: 2010
groups:
host: 192.168.1.27
port: 9292
resolvenames: json
username: Admin
password: <>
path: /groups
hosts:
ccu3:
host: 192.168.1.27
username: Admin
password: <>
Iβm completely new to both tools and might have overlooked something.
I have deactivated the authentication on the CCU as I read that this is sometimes the issue. Anywhere else where I need to look?
Best,
RenΓ©
