Since a couple of days, could be since latest 0.117.5 update, Home Assistant loses the MQTT connection to Mosquitto. Restart of Mosquitto add-on solves it, but after some time (30 minutes) it happens again.
Very annoying because I have a lot of zigbee2mqtt devices that become unavailable then.
Mosquitto broker always show this error in the log, which is quite useless:
1605090136: Saving in-memory database to /data/mosquitto.db.
1605090137: Error: No error information.
Home Assistant log shows this:
Logger: homeassistant.components.mqtt
Source: components/mqtt/__init__.py:1015
Integration: MQTT ([documentation](https://www.home-assistant.io/integrations/mqtt), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+mqtt%22))
First occurred: 10:50:38 (2 occurrences)
Last logged: 11:22:21
Disconnected from MQTT server 192.168.178.51:1883 (1)
I reinstalled the Mosquitto broker addon a couple of times, but that also does not solve it.
Do others also experience this?
