Hi
The connection with Vera have been very good until now. It broke at 40.0, what happens was that sometimes all zwave devices just disappeared. It was not a big problem because a reboot fixed it.
Today i notice same problem, but a reboot dont get it too work. I did try upgrade to 40.2 and downgrade to 39.3, still dont work.
This is the error
17-03-24 07:00:12 ERROR (Thread-5) [homeassistant.components.vera] Error communicating with Vera API
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py”, line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py”, line 83, in create_connection
raise err
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py”, line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py”, line 356, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.4/http/client.py”, line 1090, in request
self._send_request(method, url, body, headers)
File “/usr/lib/python3.4/http/client.py”, line 1128, in _send_request
self.endheaders(body)
File “/usr/lib/python3.4/http/client.py”, line 1086, in endheaders
self._send_output(message_body)
File “/usr/lib/python3.4/http/client.py”, line 924, in _send_output
self.send(msg)
File “/usr/lib/python3.4/http/client.py”, line 859, in send
self.connect()
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py”, line 166, in connect
conn = self._new_conn()
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py”, line 150, in _new_conn
self, “Failed to establish a new connection: %s” % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6e748130>: Failed to establish a new connection: [Errno 111] Connection refused
File “/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py”, line 423, in send
timeout=timeout
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py”, line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File “/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py”, line 376, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘192.168.1.100’, port=3480): Max retries exceeded with url: //data_request?id=sdata (Caused by NewConnectionError(’<requests.packages.urllib3.connection.HTTPConnection object at 0x6e748130>: Failed to establish a new connection: [Errno 111] Connection refused’,)
