I would like to share my yaml file for the Connectix Smart Gateways Wifi Water Meter. This device measures water consumption from an analogue water meter.
The company behind this device is not willing to share any details about the board and pin setup inside and is mentioning that flashing the device with your own firmware will void the waranty. No judgement call from my side, just stating the facts as they are.
Anyhow, since the company did not share the details needed to do the conversion to esphome, I decided to crack open the casing and peek inside. Itās a NodeMCU-32S and the sensor is connected to GPIO19. Based on this information, I created the yaml config below.
The internal_filter is set to 200ms since my water meter gives one pulse per 1 liter of water usage. Given the maximum speed at which i can use water, i choose for this number to prevent false-positive pulses (observing a non-existing pulse) without creating false-negative pulses (missing a real pulse). This setting works perfect in my situation, but you can tune it if needed.
total water usage. This can be used in combination with the Home Assistant Utility meter. Donāt forget to enable āPeriodically resttingā in the utility meter settings since the āTotal Usageā sensor will drop to 0 when disconnecting the sensor from power.
I did not want to store the sensor value internally, since this would lead to level wear of the flash memory.
All in all, this is a major improvement over the stock firmware due to 1) tighter integration to home assistant, 2) more control, 3) no more unneeded sensor updates every 5 seconds while no water was used: the esphome solution will only update the sensor value when another liter of water is used. 4) no internet connection is required to check for firmware updates, since you do this locally with esphome.
PS: flashing is really simple since the device has a usb-connection to deliver power. Donāt forget to push the reset-button at the beginning of the flash process.
if water was used while home assistant was rebooting, it will catch-up
if power to the water meter itself would be lost somehow, it would not calculate water usage anyway. So no difference there. When reconnecting power, the total meter will jump to 0, but the utility meter sensor will handle this scenario just fine.
thanks for responding! I am newish to esp32ās so when I see that yaml it looks like HA code and not something I would flash to the esp itself, so I am a little lost on the firmware flashing part is all
I did some digging around to figure out how this all works and I think I have it. for future reference for anyone that might be interested hereās what I did
install esphome! you can connect this with home assistant, but for now you donāt need to
adopt the device to your network, I did it via the Web - ESPHome wizard when it was connected to my laptop
check everything is working, that you can open the web portal for the device and/or ping it, and that is shows up in esphome as online
apply the yaml here from @pimw, make sure you edit as needed
Hi, i just flashed my connectix watermeter with ESPhome, and it works wonderfull. Better than the original firmware, and costumizable which is a real bonus.
Im wondering is since i also have a connectix āslimmemeterā P1 reader if it is possible to also flash this device with ESPhome. since on a regular basis i experience disconnects from this device which works with MQTT and by the way this was also the case with the āwatermeterā.
How would i go about this?
I will have a crack at it, tonight to see ad which port the data input is connected and try somethings out.
having this device local in esphome would be very nice. next to the already stated above, I would love it to not be calling āhomeā continuously, the stock which the device is doing (if only to check for updates, but recently added was the optional cloud storage of your data).
I do wonder if the Esphome version also has the āAIā sensor for leakage.
at first believed hat to be a gimmick, but got tone honest, it is quite clever (a toilet flush that keeps running, or worse, the pond refillā¦)
I have managed to get the Slimmemeter P1 from Smartgateways to work with ESPhome.
The GPIO pin that is used is āGPIO18ā.
Also I donāt know if it is hardware specific or that my particular electricity meter just send the telegrams in a different format but the inverted option of the uart settings needs to bet set to āTRUEā.
I have included the yaml coding for my unit of smartgateways.nl
esphome:
friendly_name: DSMR Meter
comment: NodeMCU-32S
esp32:
board: nodemcu-32s
# framework:
# type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "api key here"
ota:
password: "randompassword"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "ssid"
password: "password"
captive_portal:
uart:
baud_rate: 115200
rx_pin:
number: GPIO18
inverted: true
rx_buffer_size: 1700
dsmr:
max_telegram_length: 1700
- platform: dsmr
energy_delivered_tariff1:
name: "Energy Consumed Tariff 1"
filters:
- throttle: 60s
energy_delivered_tariff2:
name: "Energy Consumed Tariff 2"
filters:
- throttle: 60s
energy_returned_tariff1:
name: "Energy Produced Tariff 1"
filters:
- throttle: 60s
energy_returned_tariff2:
name: "Energy Produced Tariff 2"
filters:
- throttle: 60s
power_delivered:
name: "Power Consumption"
accuracy_decimals: 3
filters:
- throttle: 1s
power_returned:
name: "Power Produced"
filters:
- throttle: 1s
gas_delivered:
name: "Gas Consumed"
accuracy_decimals: 5
filters:
- throttle: 5s
- platform: uptime
name: "DSMR meter Uptime"
- platform: wifi_signal
name: "DSMR meter Wi-Fi Signal"
update_interval: 60s
- platform: copy
source_id: gas_consumed
name: "Gas Consumption Per Hour"
accuracy_decimals: 1
device_class: ""
state_class: "measurement"
unit_of_measurement: "m³/hour"
#We measure the delta between current en previous value
#Ignore high bootup values (above 100)
#Since we measure per 60 seconds, we need to multiply by 60 to get the hourly consumption value
filters:
- lambda: !lambda |-
static float last_value = 0;
float change = 0;
change = x - last_value;
last_value = x;
if (change > 100) return {};
return change*60;
text_sensor:
- platform: dsmr
identification:
name: "DSMR Identification"
p1_version:
- platform: wifi_info
ip_address:
name: "DSMR meter IP Address"
ssid:
name: "DSMR meter Wi-Fi SSID"
bssid:
name: "DSMR meter Wi-Fi BSSID"
- platform: version
hide_timestamp: false
Hi all,
Iām not that familliar with ESPhome, could someone point me in the right direction.
I would like to led the blue light thatās on my board connected to GPIO2 to blink every time a something gets published to the API of home assistant, or when de ESP read a telegram. Is this possible?
The official software stores the watermeter value and adds to that with each pulse. This allows for adding water usage easily if the sensor was not working for a while for example.
This implementation only seems to count pulses. How would I go about setting and adjusting the total water usage?
