Connnect Roowifi
Hello All,
Has anyone gotten a roomba with roowifi to work?
I have searched and searched , saw some shell command , saw some rest api but nothing works.
Would be greatly appreciated if someone could help connect my vacuum.
I am not a developer and this is quite challenging
Thanks if anyone can help
did you try the actual wifi roomba component?
Thanks for sugestion but had tried that already :slight_smile:
Error: [Errno 110] Connection timed out
08:01 deps/lib/python3.5/site-packages/roomba/roomba.py (ERROR)
08:00 deps/lib/python3.5/site-packages/roomba/roomba.py (ERROR)
are you using the correct IP address?
yes and the correct password and username
turn logging level to info and verify that you are actually connecting. Look for the line:
“Initializing communication with host %s (username: %s)”,
host, username)
Thanks for your quick response again ! Here is my log :
2018-05-15 08:34:55 INFO (MainThread) [homeassistant.components.vacuum] Setting up vacuum.roomba
2018-05-15 08:34:55 INFO (MainThread) [roomba.roomba.Roomba] CONTINUOUS connection
2018-05-15 08:34:55 INFO (MainThread) [homeassistant.components.vacuum.roomba] Initializing communication with host 192.168.199.126 (username: admin)
2018-05-15 08:34:55 INFO (Thread-3) [roomba.roomba.Roomba] Connecting
2018-05-15 08:34:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: s
