This has happened to me already three times as I’ve been manually inputting configs in my configuration.yaml file. Any time I save the config and check the config through UI, I get this error pop up. I don’t have any extraneous letters or anything that stands out as red flags. Any idea what can be causing this? Below is an example of one of my configs that I received an error for and below that is the error.
Error loading /config/configuration.yaml: while scanning for the next token
found character '\t' that cannot start any token
in "/config/configuration.yaml", line 28, column 1
For reference, I’m running Home Assistant Core 2021.8.3 on Synology NAS.
