Planning to clean up my config, so I’m trying to create one overall file that I can then search through to see, it some of the sensors I once created are actually still in use.
Using this command in my venv setup, I can create one file - so far, so good:
hass --script check_config --info all > /home/homeassistant/.homeassistant/all-config.yaml
But the resulting file holds a lot of entries like this one: Template object at 0x752e1490
In some cases, that doesn’t really matter, in others it seems to impact the ability to search for entity ids:
- action: ?
- data_template: ?
entity_id: <homeassistant.helpers.template.Template object at 0x752e1490>
temperature: <homeassistant.helpers.template.Template object at 0x752e1450>
service: climate.set_temperature
- condition: state
entity_id: input_boolean.ht_notification
state: on
- data_template: ?
message: <homeassistant.helpers.template.Template object at 0x752e1630>
title: <homeassistant.helpers.template.Template object at 0x752e1570>
service: notify.mypushbullet
alias: HT Turn Down Heat
condition: ?
- condition: state
entity_id: input_boolean.ht_vacation_mode
state: off
hide_entity: False
trigger: ?
value_template: <homeassistant.helpers.template.Template object at 0x75350e50>
Any other suggestions on how to creat a consolidated configuration file?
