Has anyone integrated the Conson concept 2000 domotica system in HA?
The house we bought few years ago has this domotica system where all switches, lights and blinds are connected to.
Combined with a timer module, sun/wind sensor outside all blinds close in evening when it get dark and blinds in living room open trough the timer at 8am in morning.
Off course with HA I want more control of this system.
I have the CPxx modules, while the newer are XPxx. The XP seriesalso have a network gateway with a windows application to control the system. These seem to be compatible with CP serie.
Beside that the system run on a 24v bus, but no information found so far.
I have very basic skills on electronics, so help on connecting to the bus and “capture” data to see how to control directly on bus with custom pcb also welcome.
I also have this domotica system. My switches are pulse switches so when I press the switch it sends a signal to the relay that turns on the desired relay (CP24). This way I deciced to buy a relayboard with an ESP (I used the Dingtian DT 008 from alieexpress others are also possible). This way I can make my own ‘smart switches’.
@stefdewilde if i understand correct u monitor the “lights” on the CP modules which turn red when a light is on/off?
I had contact again with Colson few month ago. they more or less confirmed that it should be possible to do this with the gateway module, BUT then i had to replace all CP modules with XP modules.
Seeing from your name, your first language is dutch … same as me
Ik heb alleen maar CP modules. De light diodes geven een ‘high’ of ‘low’ input state. Deze is verbonden met een Dingtian bord. Via MQTT verbinding naar mijn HA zie, ik dus zo of een lamp aan of uit is en kan ik de state van aan of uit veranderen in HA. Daarnaast gebruik ik de relays van het bord om een schakelaar na te doen. Zo kan ik vanop afstand ook een lamp besturen. Het is wel wat behelpen natuurlijk. Mijn rolluiken zijn ook via CP modules, maar daarvan kan ik de state (open of toe) niet uitlezen. Het zou waarschijnlijk wel kunnen, maar geen interesse om hier dieper op in te gaan. De rolluiken worden eigenlijk altijd automatisch bediend. Via een tijdsschema in HA/Node-Red. Dus niet via een CP module.
Met dit soort bordjes heb je toch de Colson helemaal niet meer nodig?
Heb je foto van je kast hoe dit is aangesloten, want denk dat ik niet goed begrijp wat je met die light diodes doet.
Onze kast begint goed vol te zitten, dus wil toch beetje vermijden veel extra draden te hebben. Zitten met 14x CP24 relay modules.
Vandaar dat ik toch nog altijd met het idee speel van proberen rechtreeks op de bus te connecteren. Volgens Colson kan je de CP modules niet uitlezen, dus moet je zelf ergens een state bijhouden. Dit zou met de XP modules wel kunnen. (in geval van gateway module dat op beide zou werken)
Als blijkt dat de modules moeten vervangen worden, dan zal het toch geen Colson meer zijn
Ik zou inderdaad de conson niet meer nodig hebben. Voor in mijn garage buiten heb ik al alles aangepast. Binnen gaat het ook over zo’n 23 modules (voedingen inbegrepen), dus ik moet er eens mijn werk van maken. Het probleem is dat het veel werk is. Geen idee of je de XP modules kunt uitlezen via HA of MQTT of … Ik heb ze niet en als ik moet vervangen zal het inderdaad geen Conson meer zijn.
Je kunt dit bv ook gebruiken om feedback op je schakelaar te tonen als deze dit ondersteunen (bv licht aan, schakelaar licht op, alleen wordt dit zelden gebruikt in België)
Het is wel een redelijk spaghetti geworden. Gelukkig loopt het maar via 24v.
Een tweede reden waarom ik het nog niet aangepast heb naar alleen maar Dingtian bordjes, is omdat het nog altijd Chinees is. Geen idee hoe veilig dat spul is natuurlijk. Een echte Europese oplossing vind ik niet.
Hi! I sent you some private messages but I think that other might benefit from the conversation here
I used google translate on your comments and I think I more or less understand the concept of reading out the state of the light. In my case, I would be super happy if I could have at least one smart switch to turn all of the lights off. I can live with switching them on and dimming them manually, especially that I added multiple new light sources that I can control in HA.
Could you please explain how you mimic a button push? I have several switches that are programmed to turn all of the lights off. Is there a way to add a smart switch/relay that would trigger this action? It feels like the “all lights off” is more complicated and kind of like conson internal automation. If I add relays that connect to specific light modules, I would need to connect to all of them to turn all of the lights off, right?
I was wondering if it is possible to connect directly to a wall switch and trigger/mimic a button push without actually pushing the button.
The worst case scenario could me something like a fingerbot I suppose.
So my light switches only send pulses to a relay that then turns on. Because I have multiple switches for the same light a cross the house, all those cables that have the pulse come to one point that then go towards the relay that turns on the light.
The ‘smart’ pulse is through a relay that goes on for 200ms and then back off.
In my case, I understood that any button anywhere in the house can do anything that the system is programmed to do. So I have maybe 5 buttons that turn off all of the lights, some turn on all of the lights, some will open the outside gate or turn on the lights in 2 rooms and dim them to 20%. All that can be re-programmed so that some or all of the buttons have a different function without any re-wiring. Do you have the same setup? All of my switches are connected between each other and a module/modules in the switch box. This is why I am wondering if I can trigger the “all lights off” with a relay that you mentioned or not.
Yes, it is conson concept 2000 but I have many different modules. Relays, dimmers, IR links, switch links etc. I did not install them, so I do not know much about it. I have some kind of programming device for it as well but the program needed only runs on very old windows systems and I had no luck connecting to my system to re-program it.
On page 5 you see the CP24. Connection diagram relay module shows all the connection and what they do. Terminal H to L sends a ‘high’ input that you can read with an ESP32 board. That’s how I know if a light is on or off.
‘Terminal Control input relay’ is what receives a high input from your switch.
This is a simple example how everything is connected with one CP24 and a dingtian board that I use.
Hi ,
nice to see that their are other users trying to get their Conson Concept 2000 CP24 Modules smart.
I do also have a Conson installation which I installed by myself in 1998.
In 2018 I went a similar way then @stefdewilde .
I have a Fhem SmartHome System on a Raspberry Pi and a 8x Relais-board.
The RPi triggers the relays from the Chinese board. These Relais are in parallel with the hardware switches in my rooms. These switches are on the 24V circuit made by the CP11.
To know if a Conson relays is ON or OFF, the pin from the corresponding red Led is connected to a GPIO pun of the RPi.
In 2018 it was my prototype mount to test if it would be possible. It is possible and the whole system still hangs their , never finished, but it works without problems.
Now, as I want to enlarge the system with new products, I realize that I do not know anymore how I did it in Fhem and I thought it would be better to come over to a newer system like HA.
It would be cool if we could share our plans with Conson and HA.
@Fallonsnest You say you have a programing device for Windows, thats interesting, could you share more information? Is this the ConBeam to be connected to a PC running the software ConTool?
I have ConKey Remote control which may be used to program the modules by IR, when held at very short distance from the module. I hope it still works, I did not use it for 25years. It looks similar to the Bang & Olufsen Beolink 1000 from these days.
I do not a programming device for Windows, i once found information on there site where they mention software to program the system.
I’m still looking for a good way to integrate the concept 2000 into HA.
It’s nice u can read the module by extra wire and add relays to control them, but that feels like making your own domotica system.
Still want to see if it’s possible to create a device, for example ESP to connect directly to the bus wire and try to reverse engineer the protocol to create a device that can read & control the system that can be plugged into the bus.
Tried contact colson multiple times, there last solution was to replace the CP modules by XP modules and add a network gateway module to it.
@gBivi as u installed the system yourself, u might have some extra info on the bus wiring?
I believe I have some programming tools and the software on a CD. I will take a picture of what I have and post it here. I tried to use it once with the help from a person who installed the system but we failed in the end. To be honest, I unfortunately don’t even remember why we failed. I know we needed a very old PC running windows XP or lower, as well as some adaptors to connect the PC to the tool. I tried to get everything but we did not establish a connection in the end.
It feels like last chance to get hold of the right HW to re-program the Conson system.
I was also told by Conson that I could switch to newer modules to control them through my phone but I was not sure if that would put it any closer to controlling the system through HA.
What do you think an alternative could be? Let’s say i want to replace one of the dimmer modules with a Shelly dimmer. Would it be possible to do so and to add a “smarter” wall switch connected through the current wiring to the new dimmer?
I received the same message from Colson. Upgrade all module from CP to XP and add the internet gateway module allow u to control it remotely trough mobile app. So it must use an API, but did not find any information about it yet.
Also they never replied when i asked what the cost would be to upgrade.
To be honest, if u need to upgrade from CP to XP, u most likely get something better for the same money that has HA integration.
@Fallonsnest
Unfortunately I do not have any info on the bus.
The difference I was told of between CP and XP,
CP = bus 3 wires + - data
XP = bus 4 wires + - data in data out
On XP you have the status of the relay on the bus, with CP only the switching command is sent, no feedback information.
Before the XP existed, there was also a CP module to connect the bus to the ethernet. I think to remember that the XP ethernet module was compatible to the CP line, without the feedback information.
I used the Conkey to program my system, that’s this device:
The Conkey is like a remote control which you can place very near (1cm) to the module you want to reprogramm.
On page 44 of the pdf you see a picture describing the programming process of a module. @krkr
it would be very interesting if you could give us some pictures of the hardware you have, and perhaps you could also share the software.
I think you could replace the CP dimmer by a shelly dimmer. But as far as I know, you can not hard wire your existing push button or switch to the shelly, because the hardware switches trigger a 24V DC “signal” +/- from CP11
But what i thought of , but did not test yet, is to put a shelly i4 behind the physical switch which you want to use to control the dimmer. Normaly the switch should have the 24V from the CP11 to power the i4. But keep in mind that the CP11 has a powerlimit (W)
For your ALL OFF automation you could perhaps use a shelly UNI.
If you place it parallel to an existing ALL OFF switch you could trigger it by the App, or with the former mentioned i4 for exemple.
Hi all, I wanted to let you know, that there is an opensource library to manage your conson XP modules: https://pypi.org/project/conson-xp/
From my experience, the XP130 bridge also works with older CP modules. The XP protocol is a backward-compatible upgrade for your bus, though I would still recommend upgrading your installation if possible.
