I’m running on an rpi 3b. Home assistant constantly crashes with nothing pertinent in the logs. When I go to access the web ui I just notice “Home Assistant is starting, not everything will be available until it is finished.” it’s happened 3 times in the last 8 hours that I know of. I’m running 2022.6.1. What should I be looking at here? I trust it’s not this unstable for everyone???
Logs from before the most recent restart:
2022-06-03 17:17:36 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2022-06-03 17:17:36 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 367, in _handle_entity_registry_updated
await self._sync_helper(to_update, to_remove)
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 311, in _sync_helper
await self.async_get_access_token()
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 173, in async_get_access_token
raise alexa_errors.RequireRelink
homeassistant.components.alexa.errors.RequireRelink
2022-06-03 17:17:58 ERROR (SyncWorker_17) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:18:02 ERROR (SyncWorker_17) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:18:05 ERROR (SyncWorker_17) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:18:05 ERROR (SyncWorker_17) [roombapy.remote_client] Unable to connect to 192.168.1.130
2022-06-03 17:19:28 ERROR (SyncWorker_12) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/67f4b1af_weatherflow2mqtt/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 67f4b1af_weatherflow2mqtt:
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_zwavejs2mqtt/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for a0d7b954_zwavejs2mqtt:
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_configurator/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_configurator:
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/7c966942_emulated_hue_dev/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 7c966942_emulated_hue_dev:
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-06-03 17:19:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-06-03 17:19:30 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-06-03 17:19:31 ERROR (SyncWorker_12) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:19:34 ERROR (SyncWorker_12) [roombapy.remote_client] Can't connect to 192.168.1.130, error: [Errno 113] Host is unreachable
2022-06-03 17:19:34 ERROR (SyncWorker_12) [roombapy.remote_client] Unable to connect to 192.168.1.130
