In the MQTT control panel, Click the actions menu, select advanced actions, and you should see this screen, click on NVM management. FWIW, I create a backup after every time I’ve successfully added a new node
Thank you for beeing so kind to help… Unfortunately I can not reach the MQTT control panel after upgrading ZWaveJS2MQTT to version 0.45.0 . I suspect that there is something wrong with the instalation:
I have one Z wave JS integration where the server url is ws://core-zwave-js:3000.
I have one Zwave JS add on with host name core-zwave-js
I have one Z-Wave JS to MQTT add on with host name a0d7b954-zwavejs2mqtt
It seems to me that the integration should point to server ws://a0d7b954-zwavejs2mqtt:3000 ???
I have tried to re configure the server (in the integration) but it refuses to connect to ws://a0d7b954-zwavejs2mqtt:3000 with the error ! Failed to connect
CAN I reinstal the zwave JS integration and add on and the zwave JS2mqtt without loosing all the devices and nodes on thre USB Stic???
If I had employed your backupstrategy I would be better off now…
I don’t know much about that. I run in Docker and have HA in one container and zwavejs2mqtt in another. From what I read, installation issues like you describe are fairly common. Hopefully someone knowledgeable will be able to help.
Sorry but there is one unclarity. I have read that the structuring of data in the 7 stick is different from the 5 stick Do you positively know that this method will work for the Aeon 5 stick to the 7 stick?
I also find it strange that i can not find any guide or tool for this on Aeons site?
I have now introduced a USB2 hub between the PC and Aeon Stick 5. It has been running for 48hours and I still loose nodes. The easy way to get them back is to ping them. I have a Aeon 7 stick also but have not tested it yet. I do read in this forum that people are ALSO loosing nodes with this stick.
I think a solution could be to ping nodes automatically and regular or even better when they are lost. I do not however know how to detect when a node disappears?
I am sad that the system is not fully trustworthy and I am close to remove security functions from it.
There seems to be many other experiencing similar problems like:
All non batery operated nodes has been lost. I tried to reinterview them but that has been going on for 24 hours without any results. I do have a NVM backup but I am not sure how to restore. If I press restore under NVM Management i get some warnings and then it ask for the file. Is this the file under store → backups → nvm → NVMxxxx.bin ?
This file is not accessible through the SMB share and I am runing the UI on a windows machine… AT the bottom of the Store its a Settings wheel. If I mark the backup file and press the settings wheel this menu pops up:
The green menu button is restore… IS THIS WHAT I USE to restore?? I can not find any documentation on this…
Can someone advice on what is the best and working strategy to get my system upp and runing… Is it to use the NVM backup? If so how is this done in detail?
I seem to have several problems with the Zwave network and nodes.
I constantly loose contact with nodes (YES i am using USB2). They can be restored by a simple ping
A loose all the nodes and or a large portion of the nodes from time to time. Either in connection with upgrades or adding nodes.
How does you controller statistics look?
I would back it up using windows if possible, and update the firmware on it. Mine is FW: v1.2
SDK: v6.7.0.
Any repeating errors in the debug-log?
What would be the best strategy. Should i upgrade first or should i restore the NVM backup and then upgrade ?.. I also have a Gen 7 so perhaps move over to that and restore NVM TO THAT
Due to incompatibility between the NVM for FW 1.1, SDK v4.54.0 and the current FW/SDK it WAS NOT possible to to use the NVM backup in Z-wave JS2MQTT! I might have worked if I had used the Aeotec tools and transfered to anothe stick but I did nor know so bad luck… I ended up with rebuilding the entire network which took me two days!!! My procedure was :
Backup of NVM of the Gen5 stick inside HASS
Upgrade FW to 1.2 and SDK to 6.7 with the Aeoteck tools (I took a backup using the tools for this and tried to use that but it did not work. I also tried to use the restore of NVM in JS2MQTT but did not work)
Rebuildt the entire network by including all devices and go through all logic and automations (a large job)
System is now stable and there is no lost nodes
Learning is to take too many backups rather then too few and to keep FW up to date
Hi everyone. This is an old thread but with a problem stil there. A year has passed and the problem of loosing zwave nodes are stil there. I can not see that anyone has come up with a solution and it does not seem that other systems have the same problem… Any one know if there is a solution…
I am close to give up on Zwave in HASS as Zigbee / WIFI does not havce this problem…
