Hi-
I have an app with an constraint like so:
constrain_input_select: input_select.holman_mode,Present,Guest
I just tested and that app is running running when that input_select.holman_mode is set to other values. I’ve checked that everything is named correctly. This is using the appdaemon:latest docker image. This used to work but it seems like maybe it broke when I added mqtt to this app. Any hints on where I should start debugging?
import appdaemon.plugins.hass.hassapi as hass
import appdaemon.plugins.mqtt.mqttapi as mqtt
class AutoLightsMqtt(mqtt.Mqtt, hass.Hass):
Am I doing this wrong?
