Consumption zigbee (blitzwolf)
hello,
how can i get the actually consumption for my zigbee switch?
its a BlitzWolf BW-SHP13
the switch should monitoring the consumption. but HA shows nothing
Look at the connected entities on the zigbee intergration page. There you should find an entity for the power consumption
hmm, where?
Check the attributes of these entities in - Developer tools - States
@ sjee
there is nothing
@ spokin
thx
and how are you deconz “settings”?
firmware update …
… did not help either
I know it won’t help, but with Zigbee2MQTT all required attributes are present. Same device, different coordinator device and different “middleware”.
after a deconz update, still no success. i had removed the device and add a new… but ;(
i see here a different between the vendor name:
my:
_TZ3000_g5xawfcq
TS0121
@spokin
Heiman
TS0121
EDIT
Found this… seems there are different SHP13 versions available.
i think HEIMAN works, _TZ3000_xxxxx not
Hi guys, for me the consumption started to show after updating the firmware to 26720700. No re-pairing needed. Previously it only allowed me to see the power.
