Containerd 3% cpu usage with haos_ova-10.1.qcow2.xz
if you fresh boot haos_ova-10.1.qcow2.xz, type login on the console and then top, then press V, it shows containerd uses 3% of the CPU all the time, that happens on my updated image as well not just on a fresh install. I’m pretty sure it’s a regression, haos in the guest used to use 0% cpu when idle.
The CPU usage of the qemu/kvm process in the host as well was 0% since I moved from usb-passthrough to pci-serial (documented here), but now it’s about 6% and the reason is containerd that uses CPU in the guest when idle, not anymore anything related to the usb zigbee adapter.
Thank you.
