Wanted to share how I got wake_on_lan to work properly when running home-assistant in a containerized environment, without giving the home-assistant container host networking privileges. (I’m running home-assistant on kubernetes+flannel, but the same should apply to folks using docker as well)
Context: wake_on_lan relies on broadcast traffic, but this is not usually possible within the overlay network used by most containerized setups.
My solution was to run a limited secondary container with with socat with host networking privileges. This accepts a unicast wake_on_lan from home-assistant and re-broadcasts to the network.
apiVersion: v1
kind: Namespace
metadata:
labels:
app: wakeonlan
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: wakeonlan
spec:
selector:
matchLabels:
app: wakeonlan
replicas: 1
template:
metadata:
labels:
app: wakeonlan
spec:
hostNetwork: true
containers:
- image: alpine/socat:latest
args:
- -dd
- UDP-RECV:9999
- UDP-SENDTO:255.255.255.255:9,broadcast
ports:
- name: wol
containerPort: 9
protocol: UDP
resources: {}
apiVersion: v1
kind: Service
metadata:
spec:
ports:
- name: wol
port: 9999
protocol: UDP
targetPort: 9999
selector:
app: wakeonlan
type: LoadBalancer
loadBalancerIP: 12.34.56.78 # my-wake-on-lan-doimain.home
And then inside home-assistant, whenever I need to wake_on_lan
service: wake_on_lan.send_magic_packet
mac: 78:5d:c8:12:8d:03
broadcast_port: 9999
broadcast_address: my-wake-on-lan-doimain.home
