PVA aka “Carola” uses ChatGPT in gapfill mode, which means, any not as configured command recognized sentence will be sent to ChatGPT and answere. It’s possible to talk to the assistant as if it would be a “normal” person…what ever is normal for ChatGPT
Hardware
Fedora Linux Desktop PC with PVA Instance
As much as we appreciate your project, an entry in this contest is only applicable if you are using Home Assistant, and building on Assist, the voice assistant inside Home Assistant.
