I’m trying to build a context-aware temperature sensor for an electric sauna, and I’d like some feedback on the right approach in Home Assistant.
Background / problem
I have two temperature sensors:
sensor.temperatuur_sauna
→ inside the sauna
→ reliable when the sauna is ON
→ unreliable when the sauna is OFF (it keeps reporting very low values like ~2 °C instead of becoming unavailable)
sensor.temperatuur_buiten_sauna_auro
→ outside, near the sauna (still inside a building)
→ always reliable
→ good proxy once the sauna has fully cooled down
I also have a binary sensor:
binary_sensor.sauna_operating_message
→ on when the sauna is actively operating
→ off when it is not
This combined temperature is used for ETA calculations and scheduling, so it must be predictable and not jump to nonsense values.
Functional goal
What I want conceptually:
Sauna ON
Always use the inside temperature
Sauna OFF, short time ago (grace period, e.g. 15 min)
Still use the inside temperature - use the last meaningful value (any value above 20 degrees is valid);
Do not immediately switch to outside
The sauna does not cool down instantly
Sauna OFF, longer than grace period
Use the outside temperature
At that point it’s a better approximation than the stale inside sensor
Important nuance:
The inside sensor does not become unavailable when wrong — it keeps reporting plausible but incorrect values (like 2 degrees Celcius). So this cannot be solved with simple availability checks.
What is the clean, maintainable HA way to model this kind of contextual sensor?
If anyone has solved a similar problem (e.g. ovens, saunas, hot tubs, boilers with bad sensors when idle), I’d love to hear how you approached it.
If the sauna operating binary sensor is a template sensor then the template above can be simplified by including a delay_off option of 15 minutes in the template binary sensor. That way there would be no need to check for last_changed and the template if condition test becomes:
{% if is_state('binary_sensor.sauna_operating_message','off') %}
That was indeed the solution. I was trying to solve everything by building all logic in one template sensor.
But now I created one template sensor that is only available when the sauna is actually on (availability: {{ is_state(‘binary_sensor.sauna_operating_message’, ‘on’) }}).
And then I could create a second, contextual sensor that can work with the last valid state of the previously created sensor.
Thanks!
Thanks for trying to help. However, the logic I needed is more complex than that. In that 15 minute window, it should not just take the current temperature from the inside-sensor, but it should take the temperature from (up to) 15 minutes ago.
